Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Nov 2011
    Default TWO DREAMBOXES ONE VIRGIN SUPERHUB
    Hi guys,
    can u please help i have a similar problem to chazkelly1985!!
    I have got 2 dream boxes! a 500hd & a 600pvr
    both have their own c-lines, their own Ethernet cables
    BUT THEY ARE RUNNING OFF THE VIRGIN SUPER HUB
    but i can only watch one at a time??
    PLEASE HELP
    Nov 2008
    just plug them both in and assign each one its own ip , hpw hard can it be ?
    if you have problems on the lan , just use a lan switch to give you more ethernet sockets
    and make sure each c line is unique , no using one c line twice
    and no need to make several posts on the same subject either
    Nov 2011
    IVE TRIED THAT
    THEY HAVE DIFFERENT IP ADDRESSES?
    DIDNT WORK
    Nov 2011
    i have two different c-lines
    DK Veteran Rodbouy's Avatar
    Jul 2010
    When both are plugged in even tho one does not clear are you able to download a plugin.
    Try and see
    Nov 2011
    which plugins?
    Jul 2010
    any, just try down load cccam info from the plugin menu of the box as a test both boxes while they are both attached to router
    Nov 2011
    plugins work
    Nov 2011
    these are the mac address & ip addresses
    mac addy 192.168.0.4 dm600 original
    mac addy 192.168.0.5 dm500hd clone
    two c-lines two different suppliers
    please help thanks
    Jul 2010
    If plugins download ok then it should be clearing ok as its got a internet connection.
    See when you unplug the one the works, does the other one clear right away
  11. #11
    Jun 2011
    Last spotted in Wales
    Quote Originally Posted by whyzer View Post
    IVE TRIED THAT
    DIDNT WORK
    Your not trying to do something silly like run two boxes from a single sat feed using a splitter are you ?
  12. #12
    Jun 2011
    sounds like there both using the same ip to me
    mate
  13. #13
    Feb 2010
    Assign a completely different IP to the second one.
    E.g. 192.168.0.4 change to 192.168.2.5
    (Also make sure that your C line is entered in corrently)
  14. #14
    Jun 2011
    Quote Originally Posted by Mr S View Post
    The IP's both need to be on the same subnet as the router or it definately wont work properly. Generally, routers are set up to allow 254 other devices on the same subnet so only the last digit group is allowed to change (1-254)
  15. #15
    Jun 2011
    yeah but were talking about the unsuperhub here mate its a real crock of s....... i use mine in router only mode as i couldnt get my box working at all just kept trying to connect, changed back to router only used my old netgear an first time everything was back to being gr8
    until a firmware upate i aint using mine in modem mode
