ok lads l have an old r reg (1998) 406 2.0 petrol in and it wasnt charging and no alternator light on , replace alternator and still no light .. yes l should of checked . anyway when u rev car the battery light comes on and it starts charging , l had this on a 02 plate one last year and had to add separate wire and bulb to activate regulator but light in the car still worked the same , but this is an older one .
wot l have is a battery light working backwards ? l have disconnected now and its fine without the original battery light wire on . instead of an earth turning the battery light on if u power it the battery light comes on ?
and if u earth the original battery light wire the air con activates ?
