Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: megane fusebox
    Jul 2010
    west mids, uk
    Default megane fusebox
    Got a megane with water in engine bay fuse box.
    Tried a used one, but car not starting, does this unit need coding or just plug & play??
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    morfej's Avatar
    Dec 2008
    It's just plug and play, no coding. Find a good one
    Post a picture or any numbers.
    br
    Mar 2010
    HI,
    if its a 2002 on shape they are plug and play. They do contain the vin number but it doesn't seem to matter.
    There are different configs N2 N3 ect but itseems to be software generated in a good old eeprom. May be worth swapping but I doubt it will make any difference to it starting.
    Does it crank?
    Meat-Head's Avatar
    under hood - plug and pray
    under dash swap 93C?? eeprom and pray
    Jul 2010
    west mids, uk
    Default megane prob
    I have put a fuse box from a running car and still the same.
    Press start button and cooling fan starts and elec error displayed on dash.
    I have no output from engine ECU.
    I have a sh1t wiring diagram, and have checked ecu earths to 3 pins on ecu h1,h4 and g1, all ok.
    But I can only find 1 live to ECU from my sh1t diagram, pin D1, which is live when start button pressed.
    Anyone know if anymore lives/earths to power this ecu?
    thanks in advance, ninja
    Meat-Head's Avatar
    OK - we had one of these many many many post's ago.
    WRENCH passenger front wheel off - stick on ebay
    lift the fusebox -
    wrench bumper off (VERY VERY VERY EASY)
    The loom had chaffed 'under the passenger head light' - think it was a glowworm fault.
    for fans to come on sounds like loss of feed to ecu - DUH! - you just said that!
    Mar 2009
    check fuses on battery and battery clamp
    Jul 2010
    west mids, uk
    Quote Originally Posted by bonecrusher View Post
    Got all earths and power to ecu, so fuses are ok....
    ninja
    DK Veteran teuton's Avatar
    Nov 2009
    Mexico
    Quote Originally Posted by ninja123 View Post
    As general rule, you should have at least one permanent live feed (30) and one ignition switched live feed (15)on any ecu.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Ashraf6119's Avatar
    Nov 2009
    UK
    Check this 30 amp fuse near B+ battery terminal showing in the picture which is for power supply to the engine bay fuse box............
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  11. #11
    Jul 2010
    west mids, uk
    Default magane
    Fuses are ok, im only getting 4-5 volts from underbonnet fuse box, should be battery voltage.
    It appears to come from a unit incorped into fuse box called engine switching protection unit, so unless my 'new' fusebox is faulty, I need to star looking at where this unit takes its supply from..............
    ninja
  12. #12
    Ashraf6119's Avatar
    Nov 2009
    UK
    ninja
    Hello,
    That 30 amp fuse in AD picture is that where the fuse box gets it power from............
    Can you check if you have 12V at the 13 mm nut on fuse box............
    Thanks Ash
  13. #13
    Jul 2010
    west mids, uk
    Yes mate, battery voltage after all 3 maxi fuses, tested under load as these slow blow fuses can still read ok with a multi meter, but they are defo ok, even bypassed them to be sure.
    So, looks like another faulty fuse box, even though it came off a 'runner'
    Would still like to know what this 'engine protection unit' actually does?
    ninja
  14. #14
    Ashraf6119's Avatar
    Nov 2009
    UK
    Have you checked the wiring loom near the battery which is going to Engine ECU............There is yellow and orange wire do brake and cause this kind of problem.............
    Open that loom till near the front and look there for any broken wires............
    Thanks Ash
  15. #15
    Jul 2010
    west mids, uk
    Default megane update....
    Got this going today too!
    Heres explanation, It may help others in the future:-
    In engine bay fuse box, there is a black 4 pin multiplug, pin 4 for low speed fan, pin 3 is output to starter motor solenoid, pins 2&1 should be +12v when ign turned on, but was only getting between 3 & 5 volts.
    Attatched a wire from an ign live source in fuse box to ONE of the 2 pins and works great!
    These two pins feed ecu, injectors and cam sensor.
    Still at a loss as to where the actual fault lies, I still think I must have TWO bad fuse boxes!!
    Anyhow, payment taken and im in the pub
    ninja
