After all the help i received reading this forum i am glad that have i've helped also.![]()
Last edited by BARBADEARVORE; 3rd January, 2012 at 11:19 AM. Reason: Duplicate...please delete...thanks.
So I have tried yet another few things, here it goes:
1) ModMii 5.0.0 for SD/HDD but still get the same black screen with blue flashing drive
2) The same but now only SD - to see if it could be a compatibility issue with my HDD. Still can't get passed the black screen but no blue flashes (maybe not enough room left for the emu nand and thus getting stuck?)
The ModMii app has more options, would I be better off to try some of those? Could it be my Wii and do I need to stub other cIOS (other than 249 and 250 with DX7)?
It is not your wii.....you are essentially building a new one with the nands from modmii. It has to be a comparability issue with the hdd. You cannot run a uneek setup from sd you would have to try a sneek setup but I have never tried neek2o from an sd only setup. to try it you need to build a sneek + di instead of uneek + di. I have never tried it as I don't have a spare sd big enough to load the nand and at least one game onto it
I don't know if this matters, but i read in a brasilian forum that we need to have bootmii instaled as IOS, even if you have it installed as boot2.
Yeah I built a sneek+di with modmii for SD only, but it stalls into a black screen (w/o blue flashes). Added Wii Play as a game and had left 200mb free on the SD, perhaps too little?!
Anyway the uneek+di with 5.0.0 also still stalls into a black screen with blue flashes from the disc drive.
My HDD is a Freecom XXS 640gb, which I have been using successfully for playing with WiiFlow and USB Loader GX.
Would you know if this drive is incompatible with neek2o?
I don't really know where to go from here. Just had another idea.....You are aware that neek2o boots without an sd now. I Can launch neek2o without an sd card in and still play games as long as I use the 1 button launch them in full sneek. Try booting without the sd just with the nands folder and sneek folder in the hdd. It is definately not recognizing the nand you have built whether it be file structure or just not reading the hdd. When I get home I'll upload my nand for you to try
Well the Freecom XXS 640gb must one of the self powered HDD's that works USB Compatibility List
This Modmii I've seen talked about on here. I downloaded 5.0 but it runs like an old DOS program and there is no help files in the package. Which letter do you type in so it scans the sysCheck.csv in the app folder so it know which IOS's need updating?
Keith
2010 Golf GTD (170)
Yes I have the main menu:
W = Modmii Wizard + Guide <Start here to mod your Wii!>
U = USB-Loader Setup + Guide
H = Hackmii Solutions <Upside-Down HBC\No Vulnerable IOS Fix> + Guide
SU = sysChecker Updater <update only your outdated softmods> + Guide
S = SNEEK Installation, Nand Builder, Game Bulk Extractor
1 = Download Page 1 <System Menu's, IOSs, MIOSs, Channels, etc>
2 = Download Page 2 <Apps, USB-Loader Files, Cheatcodes, etc>
3 = Download Page 3 <System Menu Themes>
4 = Download Page 4 <cIOSs, cMIOSs>
A = Advanced Downloads and Forwarder DOL\IOS Builder
C = Build Config Files for BootMii, Wad Manager or Multi-Mod Manager
FC = File Cleanup: Remove un-needed files after Modding
O = Options
CR = Credits
E = Exit
Sorry I don't know why I didn't see it before but it looks like SU.
Keith
2010 Golf GTD (170)
MEGAUPLOAD - The leading online storage and file delivery service here you go this is a definate working setup. If you can't get this to load it is either a bad format or incompatible hdd
