Quote Originally Posted by mactattie View Post
I've now installed the d2x-v7 cios pack and run neek2o after installing the wad. Getting a bit further in that there is now continuous activity showing on my usb where previously flashed for a few seconds and nothing.
Roughly how long should the initial load of neek2o take?
What are you getting on the screen. If it is a black screen then there is a good chance the hdd is plugged into the wrong usb port or wrong file structure on the fat 32 partition which must be the first partition on the hdd or it will not be recognized. The initial boot is only a few seconds. the d2x pack is of no use to you for neek2o, cios are not required under full emulation the games load from the original wii ios, hence the excellent game compatability. Make sure the fat partition is the first on the drive and that the file structure is correct, if in any doubt download the setup from the post above yours and try that then if you want to use a different nand you can either use your own or create another one
