Results 1 to 9 of 9
    Nov 2011
    Default Deleting channels?
    I have a dm 500HD and have been trying to delete some channels but dont have a clue how to do it. does anybody know how to delete single channels form your channel list cause Ive got lots that dont work or are double channels.
    Apr 2009
    highlight the channel
    press menu on remote
    remove entry or delete
    Nov 2011
    Thanks for the reply I have tryed what you said when I highlight the channel and press menu it on gives the options to show transponder info , set as startup service and to add a bouquet nothing about deleting channel and there`s no delete button on the dm 500 hd remote?
    Apr 2009
    bring up the channel list
    find the channel you want to delete
    highlight it
    then press menu on remote
    you should see a box pop up
    it should give you the option to delete
    Nov 2011
    thanks for the quick reply my menu is different I`m using image Openpli 2.1 dont know if thats a different image you are using? It has to have somewhere to delete them but I cant find it
    Apr 2009
    yeah your right
    if theres no way to delete the channels via the box
    you need to use dreamboxedit
    send the channel list to your pc
    then edit the list and send it back
    or use a list thats already made up
    Nov 2011
    Llamaware DreamBoxEdit is the way to go.
    Import channel list from box.
    Either add channels from the raw/long list on left to your selected bouquet, or else delete the required channels from the selected bouquet list.
    When done FTP file back to dreambox, et voila !
    This also means you can arrange your channels any way you want, make a favourites bouquet, or any other arrangement you please.
    Best of luck.
    DK Veteran BlueBox's Avatar
    Jun 2008
    Buckinghamshire UK
    lets say you wanted to delete all adult channels go to DreamBoxEdit right on adult and click on delete bougeut job done
    DreamBox 500HD NewEnigma2
    Default how to add adult channels
    i have dm500 s every channel is there accept adult channels what is the easy way to put adult channels.
    Paul
