Newnigma2 v3.3.1 DM800HDse
Results 1 to 2 of 2
    Aug 2008
    Wild Mild West
    16
    Downloads
    40
    Uploads
    Default Newnigma2 v3.3.1 DM800HDse
    Newnigma2 team proudly presents:
    Newnigma2 v3.3.1
    Basics:
    Enigma2 3.2.1: 10.11.2011
    Enigma2 Plugins: 14.11.2011
    Newnigma2 Plugins: 14.11.2011
    DM 800 HD se
    driver: 09.11.2011
    secondstage: 84
    kernel 2.6.18
    Notice: Onlineupdate from v3.3 is possible.
    Changes:
    Updated: enigma2 to release 3.2.1
    Updated: new NTFS-3G driver
    Bugfix: Zydas WLAN driver
    Bugfix: default settings would be used now, but only if u flash a new image
    Added: new expert settings: now u can choose, that opkg ignore nfs/cifs shares or the internal Harddisk
    Removed: enigma2-plugin-newnigma2-wetter and ushare
    For Skinners: new screens (menu -> settings -> system -> harddisk):
    HarddiskDriveSelection - HarddiskDriveSetup - HarddiskMountpointBrowser
    Info: mkv + idx/sub not longer work with new e2. pls feel free to post in dmm forum.
    changelog e2: dm800hd se
    Only necessary if there is no actual image with SecondStage 84 installed.
    IMPORTANT: Starting today (that was 05.09.2011) images for the models DM500HD, DM800 SE and DM800HD PVR include an improved flash error correction feature.
    In order to benefit from the improvements, it is required that you either flash the new image with the latest version of DreamUP (V1.3.3.9) or flash a new second stage loader ( DM500HD DM800HD PVR DM800 SE ) before flashing the image via your browser or other means.
    Nur notwendig wenn noch kein aktuelles Image mit SecondStage 84 auf der Box installiert ist.
    WICHTIG: Seit dem heutigen Tag (das war der 05.09.2011) enthalten die Images f?r die Dreambox Modelle DM500HD, DM800 SE und DM800HD PVR eine verbesserte Fehlerkorrektur f?r den Flash-Speicher.
    Um die Neuerungen benutzen zu k?nnen, muss entweder ein vollst?ndiges, neues Image mit der neuesten Version von DreamUP (V1.3.3.9) geflasht werden, oder zun?chst ein neuer Second Stage Loader ( DM500HD DM800HD PVR DM800 SE ) installiert werden, bevor dar?ber ein neues Image geflasht wird.
    SECONDSTAGE DOWNLOAD: DM800HD se
    here u can find USB to UART driver
    info: since release of e2 v. 3.2 there is no dm7025 support yet. that's what dmm said.
    Multiboot: No support for multiboot. Not planned. No need for such a tool.
    GP3wizard: No support for gp3wizard. Probably not running. Not needed in Newnigma2 environment.
    Your
    Newnigma2 Team
    ***Download***
    ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
    Oct 2012
    Downloads
    3
    Uploads
    Default i need the image
    i need the image
    thank u
