Results 1 to 15 of 27
Thread: Few Questions.
    Nov 2011
    Default Few Questions.
    Hi all i've been reading threads on this forum over the last few weeks. I've ordered the dreambox 5000S and i'm due to recieve it tomorrow.
    Just a few questions. I have a sky box which is set up out in the kitchen. In order to set up the dreambox is it just a case of taking the necessary wires out of the existing sky box and putting them into the dreambox?
    Will the eye that I bought for my sly box work with the dreambox?
    I'm a complete novice at all this so try and keep it in layman terms
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    hooking the satellite cable up to a standard dreambox will get you all the fta channels available on sly uk.
    Nov 2011
    So basically all I need to do is take the wires out of my existing sly box and put them into the dreambox ? Sly is currently channel 9 on my tv when I put the wires into the dreambox will it still be the same Channel?
    Will my existing sly magic eye work with my dreambox?
    Dec 2010
    192.168.1.xxx
    nooo, dremabox has to be hooked to tv via a scart cable or component.. ur sky channel will come on when u turn the dm on.. i dont think the magic eye will work mate..
    Nov 2011
    Quote Originally Posted by shadyback View Post
    What My dreambox and router are about 10 foot away from the tv where the existing sly box is and that doesen't need a scart cable I dont think ?
    Nov 2011
    Basically is what i'm trying to say is.
    My tv is mounted on the wall at one end of the room. My sky box is at the other end of the room. When I get the DB i'll just be swapping my existing sky box with the DB.
    Will the DB appear on my tv if I just swap the boxes and insert wires into the DB?
    Dec 2010
    192.168.1.xxx
    no, because if your sky box is on channel 9, then i assume ur hooked up to tv with a coax cable.. via rf out? dm doesnt have rf out
    Nov 2011
    So what Will I do there?
    Dec 2010
    192.168.1.xxx
    reeeeaaaaalllllyyyyyy long scart lead
    or video sender,
    or get some more coax, couple of f connectors and a coupler and extend the sat cable to have dm closer to tv
    Nov 2011
    shit!! i'm only after moving the wireless router from one end of the room to the other. How much will the above cost?
    Nov 2011
    I forgot to add I may be using cardsharing thats y i moved the router closer to the box if that makes a difference.
    Dec 2010
    192.168.1.xxx
    router being far away from box not a prob, with wifi bridges, and long ethernet cables.. u still need to be able to SEE the channels
  13. #13
    Nov 2011
    but i thought the router would need to be beside the box which in turn the box would need to be beside where the existing sly box is?
  14. #14
    Dec 2010
    192.168.1.xxx
    nope.. just needs to be connected.. doesnt have to be in same room..,
  15. #15
    Nov 2011
    Initially my router was on a table which was about 2 foot away from my tv. The sly box was at the other side of the room. I then moved the router over beside the sly box.
    With the card sharing i'll be using my existing sky dish How does the DB connect to my sky dish?
