Results 1 to 1 of 1
    Cool DAS and WISNet Standalone v3
    382MB
    Before you can install Xentry, you must have an installed working version of DAS on your laptop. That matches the date of the Xentry you wish to install .
    Your DAS version must be no older than 3 months old. If it is older, you must set your ?laptop system date?, back to the correct month e.g. if you are using DAS 07/10, set your date back to, say, July 25th 2010 .
    Inside:
    - install guides
    - needed keygens
    - DAS Drive Restriction fix
    - Xentry 03.2011 error fix
    - unversal cal872 fix
