Hello.
someone has fixed the p0603 dtc???
thanks.
Hello.
thanks.
Soft corrupted
Hi, how do I view the photos mentioned in this section please.
hHI I HAVE SAME BROBLEM
P062B
ANY HELP PLEASE
THANKS
If I helped, please, use magic buttons reputation+thanks
can you help me i have make egr off after that car dont start go back ori flach same prob and i have P0200
Hey guys same issue ; P0200 - P062B,
Checked Injectors they have been new (850km ) ish. they got (1.2 Ohm with wiring - 1.1 Ohm without)
Checked wiring to ecu (fine)
ECU is new (went in 850 km before)
Due to had the same issue mechanic was changing everything everything was running well until now...
Cant be true that the ECU or injectors are damaged once again.
I do not have a Osziloscop, so I can just guess I m not sure about the ECU software or anything else but seems like the mechanic before missed something out what else could I check before I send the car back. If I start (injector 2 is leaking diesel from the shaft)
I can not open the picture from hector @meat-head in the first page someone a tipp how to open it?
Też by mi się przydało problem z visteon
