Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    Spain
    Default BOXER III DTC P062B and P0200
    Hello , I've a Boxer III doesn't start.
    With PP2000 has Fault code P062B and P0200. it i can't erase.
    Any idea?
    Engine: DIESEL TURBO PUMA 22DT 100CV
    Year 2008
    Senior Member djamelEZS's Avatar
    it's ecu problem with vieston dcu102 you cpu st10f275
    Meat-Head's Avatar
    has somebody tried to do a Justy22 with them red and black leads?
    Spain
    Quote Originally Posted by djamelEZS View Post
    OK. and the solution?
    * change the ecu?
    * repair the ecu?
    * make new downloading with PP2000 or diagbox? .
    Thanks!!!
  5. The Following User Says Thank You to hector For This Useful Post:
    capi (5th October, 2014)
    Spain
    Thanks friend....
    Problem "FIXED"
    There is a info flash with the solution!!
    Sorry but is in spanish!!
  7. The Following 64 Users Say Thank You to hector For This Useful Post:
    alejandrobr1995 (7th March, 2022), all4diag (10th July, 2018), autocentarvu (9th June, 2018), autoden (29th March, 2017), autoelectrics (10th May, 2017), bmotor60 (8th July, 2018), bresto100 (28th May, 2022), bricolo (30th November, 2015), brodaty (5th May, 2015), BusCan (9th May, 2019), cheero (3rd September, 2017), cole_mcs (5th November, 2018), constan (23rd March, 2020), cristi_bv (8th November, 2016), cubert (17th December, 2016), daniboy (19th May, 2020), darka7 (19th September, 2019), DFG (7th April, 2018), dolisak (6th September, 2019), eeprom241 (7th April, 2022), Fuller (1st August, 2022), giani03 (29th March, 2016), gpv (14th April, 2020), hbalazs (13th January, 2018), hetes1200 (10th March, 2017), janjamnicky (8th September, 2016), janodrgon (27th October, 2020), katona (20th January, 2024), kronk92 (21st November, 2023), larbou83 (25th January, 2019), Litowu (31st January, 2019), maniek72 (1st November, 2019), martinsixto47 (31st October, 2019), meco (3rd February, 2015), micromax (15th May, 2023), mijatx (22nd August, 2016), Min2xx (14th July, 2015), niki85 (14th September, 2019), npepo (2nd October, 2018), p1gl3t (13th July, 2018), pedro222 (12th June, 2013), picgon (26th August, 2020), plamen 63 (21st May, 2018), radioman (20th September, 2013), rumensivanov (30th May, 2020), salimane (21st September, 2022), sapopt (3rd January, 2023), spiridonas (30th May, 2018), stefan71hh (11th November, 2019), Stule (8th January, 2016), talazso (8th September, 2022), talhatufan (7th March, 2022), tellfaia (28th December, 2020), tomasete (20th December, 2017), volorucinski (10th September, 2019), vsanyi (22nd July, 2021), western6089 (19th May, 2020), WISETIGER (7th March, 2015), wodorof (3rd April, 2023), worldofchiptuning (2nd March, 2017), xifly18 (24th May, 2017), ylie86 (7th July, 2023)
  8. #6
    Meat-Head's Avatar
    Quote Originally Posted by hector View Post
    Doesn't matter you have photos which are more helpful than anything.
    Chaffed wire on metal support bar - behind fusebox - next to ~ABS - brillant.
    Did it start of had it damaged anything?
    Nice upload - nice to see no password.
    Meat
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
  10. #7
    Jan 2016
    I have same problem with my Boxer 2006 same dtcs only i have one more p0683
  11. #8
    Griunvaldas's Avatar
    Aug 2010
    DC-DC
    I have Citroen Jumper 3 (Boxer 3 same) 2.2 with DCU-102 and DTC P0683 - Glow plug relay malfunction. I tried another relay, replaced glow plugs, now got another ECU and same problem. Can't find anything to complain. There's activation with Lexia, for glow plug relay, I can see PWM signal coming from ECU, but relay doesn't activate. Anyone had something familiar?
  12. #9
    Mar 2017
    Thanks for the photos and help. I have the same problem,and these pictures fix it. Thanks from Hungary!
  13. The Following User Says Thank You to m0rd0k For This Useful Post:
    adjee (15th August, 2018)
  14. #10
    Jul 2013
    yorkshire
    Blown fuse due to POST heater plugs maybe.
  15. #11
    Jun 2013
    Hallo
    I have The same problem p062b and p0200. I checked wirning bcm-ecu, ecu-injectors, fuses all is ok.
    I opened ecu also ok.
    Any ideas ? Maybe ecu is damage?
    Auto Citroen jumper 2007 2.2 hdi 4hv 100hp
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  16. #12
    P0200 ecu is damage
  17. The Following User Says Thank You to janusz21 For This Useful Post:
    wbart (8th December, 2017)
  18. #13
    Jun 2013
    I tought so
  19. #14
    Jun 2013
    Quote Originally Posted by janusz21 View Post
    P0200 ecu is damage
    New ecu and All is fine
  20. #15
    Apr 2018
    Chile
    Thanks Man!
