    Default s-max ford sid206 siemens DPF problem
    After DPF off using sw ecusafe 3.0 online
    the bug is pressent
    i seen that engine oil rise up /the fuel is pressent in the engine oil/
    After change software is necessary unplug some sensors?
    example sensor of differential pressure or temperature sensor before catalytic converter and so example.... ???
    Help me solve this situation because there is situation wchich can damage engine !
    Thanks Pablo
    Member ESER's Avatar
    Ukraine. Odessa.
    Where the original?
    dpf off
    test and raport
    pass pw
    Thanks Macxlulu.
    test your file and raport.
    Now have unplug differential pressure sensor and temperature catalic sensor.
    Original sid206
    all sensor must work
    problem is regeneration dpf
