Results 1 to 8 of 8
    Nov 2009
    Default passat b6 strange error
    hello! I have this vw passat year 2006 1.9 tdi engine code BXE? I've scan the car with vcds and i've got only two errors
    camshaft position sensor
    17026/P0642/001602 - Sensor Reference Voltage A: Circuit: Low
    The car goes fine for about 1km then goes to limp mode. I have checked the alternator even unpluged it and still the same thing. I have also unpluged the camshaft sensor, flow meter, throtle flap the one next to the
    egr. I have changed the ecu and still the same thing. I've also checked the wires and plugs that goes to the ecu. Can anyone point me into the right direction. ?
    Regards Antmar !
    Sep 2009
    The sensor reference voltage is a 5 volt feed.
    The 5 volt is made inside the ecu and is used as a voltage supply for various sensors. When there's a short circuit (either in wiring or inside a sensor) the voltage drops as the ecu can only supply a limited amount.
    See: 17026/P0642/001602 - Ross-Tech Wiki
    Nov 2009
    Could be a ground point?
    DK Veteran markovojvodic's Avatar
    Oct 2010
    zagreb croatia
    Have you checked - do you have 5V on sensor while car running ?
    all the fuses on E box are ok ?
    Apr 2019
    Quote Originally Posted by antmar View Post
    Regards Antmar !
    Hello @antmar, I have the same problem with the same car, how did you solve the problem ?
    Mar 2016
    ireland
    there is a problem with the cam sensor harness from ecu to cam sensor plug it suffers with interference inside the main loom .. vw do a repair loom for this .. or you could make one with thicker wires .... hope this helps
    Apr 2019
    Quote Originally Posted by marty35 View Post
    I changed the cables from ecu to camshaft sensor and the problem is still repoduce.
    Jul 2010
    17026/P0642/001602 - Sensor Reference Voltage A: Circuit: Low it means that a voltage supply pin from ecu is reporting low voltage. Check AC and temperature sensors. As for the camshaft error if the error comes with a no signal explanation then you have to check the following: camshaft sensor, wire integrity from ecu pin out to sensor, ecu. Usually 1.9TDI have a bad habit to take water into PCB (electronic board) so check the connection cables to ECU as well... might be a bad PCM as well...
