ecusafe is still regenerating from time to time ... white smoke but no DTC on dashboard. So it is a cheap solution that is working but not 100%.
try to diagnose the car after ECUSAFE ) all DTC won't be present
This car drive great but was a problem with frequent communication the regeneration of the filter becuse the car owner only runs through the city. There was no errors! Mechanic from opel cut fillter and he gave me ecu to do. I tried 1.93 ecusafe than 2.0 and a colleague from the forum send me the file. On each I have max 2 000 rpm and error in the exhaust gas temperature sensor 2.
Please help.
Adam
BDM. Customer received the car, unfortunately with dpf.
the best way is to find a tuner to remove manually the DPF,
atb
Hi Mellon, did you reset the DPF soot % to zero before you wrote the DPF OFF file?
