With PP2000
Hi.
I have the same problem with 206 1.4 hdi, P1505 fault code in ecu. Airbag has no crash and no errors, BSI has no errors too. IMMO is OK.
Tried to put another ECU, but fault appears on new one too, so I think this is not ECU related problem.
Where to look for solution? BSi?
I would swap out the engine bay fusebox,these do give trouble and can cause none starters....Its worth a try and and only takes a few minutes to swap out...:-)
Its always Nice to say Thanks...:-)
Thanks I will check that, maybe will find some bad contacts
Problem fixed.
It was fuel heater's open circuit to earth, so it blowed F15 fuse all the time.
Now no errors displayed and car runs.
Min2xx (12th January, 2017)
