Hi I was just searching channels for the satellie 19.2e however only a couple of channels about 40 come up and the search in ended why is that
also when the search is on current TV then the search just finishes
help appreciated![]()
what model tm have you and did you try a blindscan on 19.2E
Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
Hi. Have you tried to do a blind search? Is your dish properly aligned to the sat?? Also what do you mean by 'when the search is on current tv then the search just finishes'? Regards.
your channel memory could be full although 40ch could be a alignment issue also. regards mdt
DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
