Help cant tune in my satellite,please help!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Oct 2011
    Hi. also dont forget to do a blind scan, if you have not already done so. The blind scan will pick up channels which are not already in the receiver memory. Good luck.
  2. #17
    Nov 2011
    How do you do a blind scan??
  3. #18
    Oct 2011
    HI. I dont know if your receiver has a blind scan option but usually you will find it in the INSTALLATION menu. Have a look and see or look in the receiver manual. Regards.
  4. #19
    digicon's Avatar
    Why the hell would he need to do a blindscan when all he needs to do is load the E1 channel list i posted dated 28/11 there may be a couple of changes but that list is pretty up to date and also has the latest sat.xml file as well.
    Secondly do not confuse someone and telll them to do a blindscan on a receiver that is not even blindsan capable.
    next time NutsandBolts i suggest you do a little research on the satellite receivers capability before posting a suggestion and confusing the OP.
  5. #20
    Dec 2012
    Default Thanks for the info.
    Here is the latest E1 channel list for you and as andiewill said you will need to load this via DBedit.
    This is a full multisat list so you can always edit out the sats you dont want
    Also trying this method.
    Will try channel list.
  6. #21
    Dec 2012
