Results 1 to 15 of 16
    antwnhszr's Avatar
    macedonia is greek....
    Default xprog-m ...... need HELP
    I greet all friends now ... received from China a new xprog - m.
    I did install the program spent the drivers .... and when I push the button to see the device ... I get message: divise silent.ti is happening; I have not update ... Please help me
    Select options,eviroment,ports & see if selection is correct.
    antwnhszr's Avatar
    Quote Originally Posted by joemajdalani View Post
    Now when I do what I tell the computer restarts ... I can not understand what happens
    smokey08's Avatar
    Essex, UK
    Click update firmware button then it will work. only use the version of xprog desktop it was supplied with.
    antwnhszr's Avatar
    Quote Originally Posted by smokey08 View Post
    I did what you told me .... when I have connection to the usb and hit the update the computer does restart ... also another thing: in Device Manager, the computer shows up as usb serial ... is sensible;
    smokey08's Avatar
    Essex, UK
    This is the video of how it should be set up. Yes it should show up as usb serial in device manager.
    Have you tried connecting it with the serial cable and external power? I dont think your usb port can supply enough power.
    jcgabbi's Avatar
    Brazil
    Try install in other computer.
    Why you use usb?Use serial cabel and it should work but than make update firmware is soft
    antwnhszr's Avatar
    Quote Originally Posted by jcgabbi View Post
    He was absolutely right ... I put on 1 laptop and working properly ... what I do but which should I use a desktop? what is broken in, and when I usb hardware info ... the computer does restart?
    antwnhszr's Avatar
    Quote Originally Posted by antibisic View Post
    my friend thank you for time... how to use the serial? after I passed drivers for usb? Thanks again for any help ....
    antwnhszr's Avatar
    actually had problems with the usb ..... I put it on laptop and functioning properly ... doulefoun.ti all I do now with the desktop? is more manageable to work on desktop press the laptop .. has no solution;
    Quote Originally Posted by antwnhszr View Post
    Very simple conect only serial cabel and external power that,s all not need usb
  13. #13
    antwnhszr's Avatar
    Question
    Sorry if the question is stupid but I'll I do ............. how many volt xprog the need for wire serial?
  14. #14
    Use 12V DC external adaptor.
  15. #15
    jcgabbi's Avatar
    Brazil
