that will be great!!!!!!
Hello
Winols map pack only works with latest and legal winols version...
greetings,
filecloud
Map packs made in cracked winols works on cracked winols. All the good stuff made by original users will not work for you crack guys
However all stuff made from the cracked stuff or original stuff works for guys with the original stuff And at 1200 euros why dispute the original that has exceptional updates and support .
im sorry, but i dont think like you!!
when we create a new map pack, its with extension kp (map pack), and we could save those map packs where we whant on our computer.
When we open some file and we have the correct map pack for the file, it wil work good. i will send 1 file and 1 map pack try it on original winols, it was craete on cracked version 1.5.
regards.
WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
You have not read carefully. Map packs from cracked versions can be opened on legal winols. But map packs from legal versions (Winols 2.10 at the moment!) cannot be opened on cracked and outdated winols 1.x.
Attached an actual map pack from legal winols. Please try to open this.
greetings,
filecloud
makmoer (26th April, 2018)
The extension files are different, .olsx and .kp. Do you know if there is anyway that they can be edited in order to work with .kp files?
Or if you save a file in OLS mode, this way will bring your maps and descriptions that you did, and it's almost the same thing as an map pack, this ols file will work on old ols?
Regards,
u can try it with the demo version!
