Results 1 to 7 of 7
    Top Poster pongo snodgrass's Avatar
    Jul 2009
    Default streaming from VU+duo to my lappy
    hi - i can stream from my vu+duo to my laptop, but picture freezes and glitchs every second..then screen goes black...im using blackhole 1.6.6 image, but there is no option in the settings to change the default port as this may be the proble...any ideas ?...you can do this with vix image by changing the default port but not in bh image...i see 1.6.7 bh is released wonder if you can do it in that ?...but i doubt it...any help and advice ? ta
    V.I.P. Member dell_xps's Avatar
    Dec 2008
    Are you using wifi bridge or home plugs ?
    What type of router are you using ?
    Jul 2009
    im using a virgin media vmdg280 wireless router/modem all in one....no wifi bridge or home plugs...
    Dec 2008
    So Vu is hard wired to router and pc hard wired to router m8?
    Jul 2009
    Quote Originally Posted by dell_xps View Post
    only vu+duo is hard wired to the router.....dont have a pc, only a lappy that i also connect wirelessly to the vmdg router....
    having issues connecting to my vmdg280 wireless router....looks like a lot of problems with this router as a google showed all this....damm more problems
    Apr 2008
    Check your wireless speed, if I move my laptop to another room, and the speed drops below 25Mpbs it does not work properly. Also it does not work properly on HD.
    Sep 2010
    if i was you , id flash ur vu+ with the latest vix image , i was using that image and had the same problems , all people said was check bandwidth. Vix image flashed and the web interface works perfectly , i stream to 2 lappys at same time now with no problem
