pin ok special thinks for you
hi I need help code ecu audi a3 06a906033j siemens 5wp40038 04audi a3 06A906033J 93C76.rar
karl Martin (24th January, 2020), polys123 (18th May, 2013), transprotector (20th July, 2013)
thanks : Congrats:
Hello all,
please can someone help to read pin from dump to match keys for a cluster from used car.
Audi A3 1.6 from 2001
Siemens Simos 3.3A 3488
06A906033J
5WP4003801
vin: WAUZZZ8LZ1A019303
immo pin or immo of please.
Attach 8 bits and 16 bits reads.
Regards.
WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
motocarlos (31st January, 2019)
amazig (31st January, 2019)
Hello
To open this ECU is like ECU15, or I may broken something if i try?
every ecu is same.............the best way is to use correct tools to open ecus
https://www.tuningtools.com/ecu-opening-tool-6-pcs.html
need help
now my goal is to buy xp-005
who will help?
karl Martin (23rd January, 2020), morgano (18th January, 2020)
I know this maybe silly question, but is ecu pin same as immo pin to code keys in? Many thanks
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
For Audi A3 8L, with immo3 dash, the ecu pin is the same as the instrument cluster pin
You have help me a lot. Believe, because i was afraid to open and make some mess. Next sunday I will have to read eeprom to find pin, but i don't have any software to decode the eeprom and find pin. May I write one dump that i already know the pin to the eeprom, and change VIN number?
Because that are my options. That or find a eeprom with immo off
Again many thanks for your precious help
