Results 1 to 10 of 10
    Bielsko-Biala
    Default Problem with turbo??? A4 AKE 2.5TDI....
    Hi everybody I have A4 2.5 tdi ake engine..... When i drive the car on 3000rpm and put off the acceleration pedal in measured block in channel 11 give me information about overboost... Real value: 1500mbar, required value: 1100mbar... then hear a sound psszszsz coming from air filter.... on idle when accelerate and rpm go down hear this: [ame=http://www.youtube.com/watch?v=hYBGfjw1EWg]Audi A4 2.5 TDI Quattro Turbo Sound - YouTube[/ame]
    THIS IS NORMAL IN THIS ENGINE???? REGARDS!!!
    Liteace's Avatar
    Mar 2009
    On a rock
    Has the engine been modified in any way ?? any bolt on goodies
    Bielsko-Biala
    No engine is stock..... all parts turbo ,N75 , Vacum pipe is ok....
    Ashraf6119's Avatar
    UK
    Check your (Barometric Sensor in ECU) also the Boost Pressure Sensor which is fitted from the Inter-cooler pipe.....................
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Bielsko-Biala
    Barometric sensor is ok.....
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by mcgustoo View Post
    Boost Pressure Sensor ????????????? Which is fitted near Inter Cooler
    Thanks Ash
    Bielsko-Biala
    Boost sensor too.....
    Dec 2011
    Mcgustoo, I think your 'pssszssz' sound could be pressure leak, or it could be connected to ur overboost problem, ur VNT could be stuck on "full load" ant the turbo is overfilling pressure.
    That's what i can tell acording to the video. For further info bring the car to my service no charges
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by biliibros View Post
    That was a month ago, im sure he's got it sorted by now
    Bielsko-Biala
    I think is normal... I have heard Audi a6 my friend with the same engine - works that!
