Results 1 to 12 of 12
    Default BMW E46 MK4 flash dump
    Good day!
    There is a problem:
    Update the navigation on the MK4 BMW E46 recorded CD with the update V32.
    Update lasted more than 1:00 and ended with flashing black monitor screen navigation. Navi unit will not accept and will not give CD. I need help!
    It is very necessary MK4 flash dump.
    Thanks in advance!
    holland
    Default bmw mk4
    Quote Originally Posted by awmalchuk View Post
    Good day!
    There is a problem:
    Thanks in advance!
    hi,
    wat is your color now of monitor screen? white?
    wbr
    Good day!
    There is a problem:
    Thanks in advance!
    You no need flash dump.Just open mk4 and take out disc.Write v29 with ImgBurn at low speed instal mk4 in car switch igniition to position1 and insert disc v29 i mk4.If your disc v29 is correctly write mk4 bring back to life.I test this method more 10 times
  4. The Following User Says Thank You to ptalev For This Useful Post:
    rawen (9th February, 2018)
    Quote Originally Posted by oemrepair View Post
    hi,
    wbr
    monitor black, occasionally flashes white
    Quote Originally Posted by ptalev View Post
    drive navigation does not want to take or give away the disc, here's the problem ...
    You have a disc in mk4?
    If have disc in mk4 remove the fuse for navi(in load area) for 15 min ,push and hold eject buton and then insert the fuse
    Drive in MK4, no, I got it. A colleague of mine found on the Internet for MK4 dump to flash k9f5608 and recorded his programmer (Omega flash). After this, the disk is not inserted ...
    Maybe something is wrong with the dump?
  9. The Following User Says Thank You to awmalchuk For This Useful Post:
    cba (6th May, 2021)
  10. #8
    If mk4 dont take disc maybe problem is hardwear.check flash and resoldering and then flash with disc
    sorry for my english but im from Bulgaria
  11. #9
    I think it can work in the dump, which recorded a colleague.
    Up to dump MK4 took and gave CDs. After the dump - do not accept CD. Can anyone has a dump from a working MK4? It is very necessary ...
    I am from Belarus.
  12. #10
    May 2018
    I am from Belarus.
    The problem is solved?
  13. #11
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Not solved,because you can't work with NAND like with regular flash...
  14. #12
    Nov 2020
    Cześć.
    Nie mogę uzyskać tego zrzutu pliku. Zalogowałem się, przywitałem się, minęło 30 minut. co jeszcze mam zrobić?
    Czy ktoś mógłby mi to wysłać na priv?
