Results 1 to 8 of 8
    Oct 2011
    Default Das 2011 07and09 all time error to instal
    I've installed many loptops DAS 2011 07 version.
    Now I bought myself the Dell D630 Intel Core 2 Duo T7250 2GB DDR2 RAM, HDD 120GB ATA.
    All the time the error pops up on the 07 and the 09 versions.
    use NewGuide2h all do that but the skin always throws error
    DK Veteran billboard's Avatar
    befor installation use "WFPswitch.exe" an full installation will be fine
    and you must do installation on "administrator" account or another with full permision rights (reading/writing/etc.)
    boobies, most of them are fake but who cares?
    Oct 2011
    this not work!!
    you have english os and you will make installation with ru interface, make whole installation in en and then add ru language to das and set ru in xentry, done.
    its the best solution for you
    p.s. dont forget to add full permission in registy for your account
    Oct 2011
    i tray not worked!
    English permission result error
    Quote Originally Posted by sunduk112 View Post
    Hi, you have used the powertool to install. So the installation part is not the problem.
    Regarding the error no 1, I think it is not a problem.
    CMIIW, Usually it is because of the localization of internet explorer. Don't bother with this error right now.
    And the other errors, they are serious errors.
    I suspect your hard drive has bad sector(s).
    Try to install using other or new hard drive.
    Hope this help.
    Oct 2011
    HI all hoo try help me!
    i made problem be in drivers.
    Junior Member Dreamer001's Avatar
    I have the same problem on a Dell D630 tried also on Toshiba.
    Always the same errors...
    Tried to install on German machine language, tried on English
    used "WFPswitch.exe"but same problem.
    Maybe some other ideas.
    BR
