Results 1 to 5 of 5
    Griunvaldas's Avatar
    Aug 2010
    DC-DC
    Default Citroen C8 DPF off
    Hello, I have Citroen C8 2004 2.0HDi.I'm trying to remove DPF. I own original EcuSafe 3.0 (online version) but the support is very poor, and it doesn't even recognize the file... Could anyone help please? Best regards!
    BOSCH EDC15C2-10.1
    0 281 011 334
    Quote Originally Posted by Griunvaldas View Post
    BOSCH EDC15C2-10.1
    0 281 011 334
    Here you go m8
    Aug 2010
    DC-DC
    Will check it tomorrow thanks!
    Aug 2010
    DC-DC
    Thanks for help, this type of car doesn't even need reflashing - with Lexia u can change configuration for DPF + also U can switch off fuel cap sensor! Special thanks to vagtech1 for all the help. Best regards
    Aug 2010
    DC-DC
    The car came back with the limp mode and no DTC in BSI & ECU. Still have to check rail pressure regulator and compression then
