Results 1 to 11 of 11
Hybrid View
    DK Veteran fifas2010's Avatar
    Sep 2010
    in the midst of war
    Unhappy IDS VCM Blocked ?
    Hello friends, I come again to appeal for your help.
    I have a VCM interface (green card) that after upgrade.., and was stopped with a single light on, the red light! and never left it.
    I've tried:
    - INTAL a previous version v73 has not resolved
    - Run the recovery tool vcm, gives error (Failed to re-load gateway software)
    interface connects to the network by ip: 172.25.236.1 strange??
    Anyone can help me, I am grateful
    BR,Fifas
    May 2011
    Illinos
    hi8, i think probably the vcm unit may be broke by the update,
    i suggest try on another computer, if it still not working, it's surely broken
    greetings
    Sep 2010
    in the midst of war
    Default I tried to run the vcmutil
    I tried to run the vcmutil, but gives error .... see fotos
    I think I lost the boot vcm, someone has to reprogram the interface dumps
    Thanks to all the members of this house
    I need dump?s files to internal reprogram, because i lost boot
    BR,Fifas
    Newbie dongyoucai's Avatar
    You can try installing a new version of this JLR, even car update, I get this last time, like you problems,
    I also have a dump file VCM
    kevfield's Avatar
    uk
    What is the dump you have for vcm ?
    is it from usb lead or from inside vcm interface?
    Thanks kev
    Sep 2010
    in the midst of war
    I still have my broken vcm, who can help me fix this ?
    BR,Fifas
    France
    simply connect a power supply + - 13volts in the round plug vcm (positive on pin inside) and rerun the vcmutil
    you can use sw to v74 but when the question ids if you want to update you have to choose not to update
    Sep 2010
    in the midst of war
    Quote Originally Posted by powerpower View Post
    Thank?s powerpower, but iff you see all my post, you see that already make this...no sucess ):
    see my post http://www.digital-kaos.co.uk/forums...6/#post1387324
    BR,Fifas
    Dec 2011
    change usb cable try again .....
    by kenwood
    have you repaired your vcm ?
    I have same problem
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Hello
    I have same problem, can anywhare help me??
    Mi VCM is 100% original Ford.
    Exist a tool to repair for VCM?
    Is possible reprogram by dump file eprom?If is possible post the files please.
    Very thanks friends
