xentry -Runs
das Does not work
ples help
xentry -Runs
das Does not work
ples help
What is your issue with DAS? This KG would unlikely help you with your DAS issue anyway.
Click on the icon whenever das Get the message at the bottom !!
welcooooom !!
Mate,
this tool is from JCrecording :-( why? "Is Sxit from JOHN!
So you can Crack it if you mean this will help you ;-)
I know the way from different Programms what we Crack I dont Try It but I am sure the Way is allways the same!
1. Install "WINHEX" input Licence
2. START your Tool, Input Name: Star and input "Fake code" maybe: E191-51E2-34F0-FBD5-4D03 and push Enter, THAN DONT CLOSE THE WINDOW!
3. Start WIN HEX,
4. Go in WINHEX --> Tools --> OPen RAM ---> Entire or Primary Memory
5. So You see hier more Process, chose tool what you will Crack (see the Name of the Tool) and Klick Open.
6. In WINHEX --> Option VIEW ---> select "Text Display Only"
7. Than WINHEX goto Option "Search" ---> Find Text ---> input opening Window the Fake Code: E191-51E2-34F0-FBD5-4D03 and Klick search!
8. So you will See then the Fake Number (E191-51E2-34F0-FBD5-4D03) BUT / AND OTHER NUMBERS, search Good and you will Find the Key what you Need.
;-) by Goran
Hi there,
it's a china installation you're talking about.
These guys protected DAS with an additional key - so that they can charge you for each machine.
How to solve:
search for the hidden file 'cal.dll'
(Programme\DAS\Bin)
and replace the modified (1.188kb) with the original one (just 48kb)
