Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 81
  1. #31
    Jun 2009
    what protek model do you have?
  2. #32
    DK Veteran bj1's Avatar
    Sep 2010
    north wales
    Quote Originally Posted by metro60 View Post
    Just upgraded my dish from a 13/19 monoblock to a system with a motorised dish with single LNB.
    My installer set the Motorised System option to USALS, and amended the long/lat figurers.
    Unfortunately, I don't know how to scan for channels on, say, 16 or 23.5, and only have what I had before on 13 and 19. Can anyone help get me started?
    Cheers!
    your installer has not done a very good job has he you should be picking everything available up,
    if you put in dickb,s channel list in and you still cannot pick the other sats up then you should call your installer back to finish the job off.
    ........bj1
  3. #33
    Jul 2012
    Austria
    Quote Originally Posted by dick b View Post
    yeah just load patch and list as normal,theres a couple more here you might like to try.
    you may also find the editor handy
    Thanks... I have been crazy noy knowing what to do ...I hope it helps, the original version was 2.0 for the protek 9760, I got the BorisT, but nothing changed... I will try tonight again...
    Thanks mate
  4. #34
    Jun 2009
    [QUOTE=Halladay;1616951]Thanks... I have been crazy noy knowing what to do ...I hope it helps, the original version was 2.0 for the protek 9760, I got the BorisT, but nothing changed... I will try tonight again...
    Thanks mate[/QUOTE
    yeah boris firmware v 17 is the latest
    but those channel lists I posted earlier are a bit out of date
    so heres some later ones 629 the 4 sat list is right uptodate and the one I use there is still a lot of rubbish on it but the favorites may be useful and the transponders are right(at the moment)
    the 616 file is for motorised and not quite upto date as I dont use a motor on the protek(theres more than enough on 4 sats)
    the 4 sats are 13E,16E,19E & 23.5E
    if you are using a motor check your co-ordinates after loading a channel list(you can use the 4 sat list with a motor if you want)
  5. #35
    Jul 2012
    hi everybody,
    i have just loaded files to update 9760 on usb, but when i plug usb in to the box it can't see any files. any help?
    thank you very much
  6. #36
    Jun 2009
    Quote Originally Posted by daryoush7 View Post
    hi everybody,
    thank you very much
    9760 auto updates what files are you trying to load?
  7. #37
    Jul 2012
    Default Bougeuts gone
    I ve tryied various firmwares and i still dont see any bougeuts.
    Protek is brand new and it shows the normal channels mostly if i unplug/plug the satelite cable!
    Any expert with solution? Would be great.
  8. #38
    Jun 2009
    Quote Originally Posted by kokoko View Post
    what model is it and is your broadband connection ok
  9. #39
    Aug 2012
    Default bouqet missing on protek box
    it was originally there and now has dissapeared any ideas?
  10. #40
    Sep 2008
    just checked mine again as it was off this morning but back now,does your box have an ip addy if not it may want a reboot to connect for bouquet to update
  11. #41
    Aug 2012
    thanks for your settings
  12. #42
    Jan 2009
    Thanks for the channel list.
    Just what I needed to make a good box,even better.
  13. #43
    Aug 2012
    Thanks for the info. Searching these forums makes all this 'new to me ' stuff sooo much easier for newbies like me.
  14. #44
    Aug 2012
    Dick B certainly drags us newbies out of the ****. Thanks pal.
  15. #45
    Mar 2009
    could i ask a couple of questions please, im a dm man i must say ..
    but if so here it comes .
    can i add a cline on these boxes .
    can i use emu mgcamd 138
    also how often do you have to update firmware ,
    and finally how reliable and what packages is this box clearing .
    the reason i ask is i got one a few years ago and they stopped suporting it ..
    just my luck ..
    dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
