Originally Posted by
Liteace
When you get this code you have to make sure you have the correct BCM for that car, its been coded correctly and has the lastest software , find someone with a Tech 2 & save yourself a headache or you are going to have to do all this:
Perform the following tests in the given order until a defect is found.
Connect diagnostic tester, select concerned Electronic System, establish communication and verify, that the correct control unit is installed:
Refer to Body Control Module Table B-003 Connect Diagnostic Tester and Establish Communication
Read and record diagnostic trouble codes including status
If a trouble code with status present is stored:
Refer to Body Control Module Table B-001 DIAGNOSTIC TROUBLE CODE
Refer to Body Control Module Table B-002 DATA LIST T005 Alternator Load Signal
Vehicle with anti-lock brake system:
Refer to Body Control Module Table B-002 DATA LIST T008 ABS Input Signal
Refer to Body Control Module Table B-002 DATA LIST T036 ABS Telltale
Vehicle with traction control:
Refer to Body Control Module Table B-002 DATA LIST T037 Traction Control Telltale
Refer to Body Control Module Table B-002 DATA LIST T009 Status Brake Fluid Level/Parking Brake
Vehicle with electrical power steering:
Refer to Body Control Module Table B-002 DATA LIST T010 EPS Status
Refer to Body Control Module Table B-002 DATA LIST T013 High Beam Signal Voltage
Refer to Body Control Module Table B-002 DATA LIST T014 Turn Signal Input
Refer to Body Control Module Table B-002 DATA LIST T017 Fog Lights Front Switch Status
Refer to Body Control Module Table B-002 DATA LIST T018 Fog Lights Rear Switch Status
Refer to Body Control Module Table B-002 DATA LIST T024 Fuel Level Sensor
Vehicle with telltale seat belt warning:
Refer to Body Control Module Table B-002 DATA LIST T033 Driver Seat Belt Status
Refer to Body Control Module Table B-002 DATA LIST T034 Oil Pressure Lamp
Engine Z 10 XE, Z 10 XEP, Z 12 XE, Z 12 XEP, Z 13 DT, Z 14 XE, Z 14 XEP, Z 16 SE, Z 17 DTH, Z 18 XE, Z 16 YNG, X 18 XF, T 18 NE
Refer to Body Control Module Table B-002 DATA LIST T035 SVS Lamp (Service Vehicle Soon)
Vehicle with diesel engine:
Refer to Body Control Module Table B-002 DATA LIST T039 Glow Time Telltale
Refer to Body Control Module Table B-002 DATA LIST T045 Engine Speed
Refer to Body Control Module Table B-002 DATA LIST T046 Wheel Speed
Vehicle with automatic transmission:
Refer to Body Control Module Table B-002 DATA LIST T040 Sport Program Indicator
Refer to Body Control Module Table B-002 DATA LIST T041 Winter Program Indicator
Refer to Body Control Module Table B-002 DATA LIST T049 Actual Gear
Vehicle with Easytronic:
Vehicle with cruise control:
Refer to Body Control Module Table B-002 DATA LIST T051 Cruise Control Signal
Refer to Body Control Module Table B-002 DATA LIST T052 Cruise Control
Vehicle with xenon light:
Refer to Body Control Module Table B-002 DATA LIST T032 Headlamp Levelling Device Status
Refer to Table C-005 BCM Communication Circuit
The equipment version "Vehicle Dynamic System" contains also Traction Control and Anti-Lock Brake System.
The equipment version "Traction Control" contains also the Anti-Lock Brake System.
