    Default BOSCH KTS POWER PROBLEM
    Hello Friends,
    There is a KTS 550 device with Ubox2 cable. We have problem !!
    - Problem is KTS doesnt take power +12v from Cars via OBD cable. no green led when you plug to the cars.Therefore no operation.
    -But if you aplly external power (+15v) to KTS via KTS power adapter , green led ligts and work without problems on all cars..
    -I checked the ubox2 OBD cable OBD pin16 , takes the power to the KTS box , and i measured the +12v inside KTS box, so No Ubox cable is broken.
    -I also checked fuses which i can found inside KTS box, they seems to OK..
    As i learnd from market this problem is very known on KTS devices..
    Any help appreciated
    Top Poster djorgensen's Avatar
    Cardiff, UK
    most probably the cable
    ive had similar problems with the kts 650
    the cable is very expensive too
    I'm a guy trying to make a living
    hello
    the problem isin the cable, you have to change it.
    ihad the same problem with my kts550
    good luck
    Bell
    Quote Originally Posted by bmn2090 View Post
    hello
    good luck
    Bell
    The cable is Ok, problem is in the KTS box i think, Because i measured the cable and the voltage +12v comes from OBD cable to KTS box..
    Hi, a friend of mine epirienced such a problem after firmware update ..., I rechecked power circuit inside all was OK. Recheck the power plug connector it has a pin that has extra function, it is connected to gnd when no power is plugged in.... regards ficho
    micromax's Avatar
    South Poland
    in kts520 is a common fault. I always link inside of the box external 12V with 16 pin obd
