Page 1 of 6 123456 LastLast
Results 1 to 15 of 82
    Default install solution Xentry 11.2011 OK
    Dear
    With the help of my friend. i have been succesfully install Xentry 11.2011.
    First.
    Download MR Zolookas guild 2h
    http://www.digital-kaos.co.uk/forums...8/#post1241251
    second..
    Change the Hardisk Serial Number (thanks to mr Selekos)
    3rd
    run the Fix from mr WSC
    4
    install DAS and Xentry via AUTOSWItch from DAS.
    5 final
    copy the setup.inx i attach in here to folder Xentry_frame/xentry..
    and see what happen..
    say thanks if u think it help..
  2. The Following 2 Users Say Thank You to nguyennhatquang For This Useful Post:
    johnnykayal (17th May, 2013), plore90 (25th November, 2018)
  3. #2
    xentry run perfectly..
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by nguyennhatquang View Post
    Dear
    First.
    second..
    3rd
    4
    5 final
    THANKSSS!!!! you know for WHAYY????!!!!
    @cocoh : thank you..u're the men.
    I tried this approach and it seems Xentry is working but I faced an issue with DAS as shown in the attached screen captures (failed to create the DAS context file DASContext.sli).
    Sounds like the problem might not be related to this DAS release or the installation approach but I have not seen this before.
    Note that I have this file at the userdata\das folder.
    Any ideas how to fix this?
    Quote Originally Posted by DB_member View Post
    I've the same problem...
    I should have mentioned that I changed the Star Diagnose registry key to COMPACT4 after applying zolookas tools.
    The key was turned to COMPACT3 after installation (the "after installation" tool makes this).
    Did others leave the registry key to BasicXP after zolookas initial tools? I thought this would disable the WIS icon from the Xentry frame? I cannot think of anything else being different from the first post.
    At this point I did not apply any time-out or blacklist fixes. Also installing AddOns did not make a difference.
    Oct 2011
    its work thank you.
  10. #9
    Can some please help with this error.
    internal fatal error: (1.75)-1.059
    xentry 11.2011 please help.
  11. #10
    I followed the guide without including step 5 and everything seems to work perfect.
    Best Regards
  12. #11
    Oct 2011
    hm xentry work but das not working(error 2173-11)
  13. #12
    Apr 2011
    Russia
    Find DAS_TEMP_DIR in files .properties and replace to real path to DASContext.sli ))) Also replace other invalid string )
  14. #13
    Jun 2009
    Antiochia \ TURKEY
    thanks for you
  15. #14
    Quote Originally Posted by autochampion1 View Post
    Thanks, now I found this file and fixed the definition and DAS appears to be running fine.
    So far I've only tested simulation mode, will have to test DAS blacklist solutions too.
  16. #15
    Dec 2010
    Post xentry install stop
    hi, friend
    Thanks for sharing good material.
    RG
    dlaskarb
