I started at the Xentry frame/setup.exe
install success!
I tested smart car with clone SDconnect interface.
work perfect!
Many thanks for all!
install success!
work perfect!
Hi all
Please help ...
xentry real diagnostic mode and simulation mode, the following error occurs.
DASContext.sli DAS_TEMP_DIR and can not find the path to the file.
Give someone a good idea and solution.
Thank you.
RG
dlaskarb
hi friend
The contents of post # 12 I could not understand.
For more information, please.
Thank you.
RG
dlaskarb
I'll try to explain this in more detail:
- locate the file GlobalSystemSettings_install.properties from F:\Programme\Xentry\bin
- edit the DASContextFile path definition to
system.diag.das.path2DASContextFile=F:\\userdata\\ DAS
You probably had there something like in the error message.
hi, DB_member
Thank you for a friendly description.
Described in detail with you, that you do not have a lot of people.
Good luck to you ....
RG
dlaskarb
hi.
xentry fail
Errors occurred during installation. Error code:0
Open eyes and attentively read post #1!!! http://www.digital-kaos.co.uk/forums...9/#post1382922
problem solved after read again post #1
Hello
I have one question is it possible to use my cardaq plus interface with das or Xentury software in order to diagnose MB trucks?
Cables are not problems i have pinout from interface and truck.
How to configure software to recognize this interface?
You can see the interface here
CarDAQ Plus
@dimitar22
The Cardaq Is the same Tool as "Actia Multidiag Acess" (the Only Free Tool for REGULAR Online Coding what is supportded from Manufacturer or Better for Euro5!).
So try Configuration (see in DK) DAS / XENTRY for Multidiag Acess maybe this Help You...
Yes is right we Crack it the Dongle last Year from Martin / Polland in Unlimited Version with Russian Guys.
I can?t Manage this steps but i can give you one Licence for your PC so that you can work with Cardaq and MC-II.
