Results 1 to 5 of 5
Thread: W210 EIS Swap
    leandroks's Avatar
    Feb 2010
    Brazil
    Default W210 EIS Swap
    Hi there i ve got a E320(w210) wich the eis has been destructed, i ve bought another one from junk yard, with key, so i am trying to adapt on the car, i ve renewed the steering lock and ecu via ak400 and used the star to adapt but no success. So could anyone tell me the right sequence??? I mean renew the ecu and steering lock and then adapt with star???? As simple as that???
    Thanks in advance
    ps: the key is sucking and the steering lock has been released but the engine do not run...
    Jul 2009
    i think u need to have the engin ecm from the same junk car
    good luck
    DK Veteran agabna's Avatar
    Jan 2010
    Default 2 mcu
    Quote Originally Posted by leandroks View Post
    Thanks in advance
    just swap the old 2 mcu to the new ezs and it ll work
    no more
    leandroks's Avatar
    Feb 2010
    Brazil
    That is the problem, the dump is corrupted.
    Cheers
    Mar 2012
    you have to have several items all from the same donor car since their VIN number is stored in each one. This would include the transmission selector module and steering lock module, and the ECU.
    I had the same problem as you, after extensive research and not having the tool to move the data from the old to the donor EIS, gave up and had the dealer install a new IES.
    the used EIS with key is pretty useless at the moment.
