Results 1 to 15 of 82
Hybrid View
    Member mercecrac32's Avatar
    Apr 2010
    Hi all, I just need to understand what means "Install DAS and Xentry via AUTOSWItch from DAS" ! May be I'm too old to play with that ?
    Sep 2009
    Quote Originally Posted by mercecrac32 View Post
    No, you cannot be too old, I would be too old then and I don't want to admit that.
    I don't think you actually need to know that, either try the normal way you've done it previously or try "SDSwitch.exe" from the DVD root.
    Apr 2010
    Quote Originally Posted by DB_member View Post
    Hi DB_Member,
    Thank you for your usual kindness. I got good install via stardiag/setup.exe. All OK in SIM mode (no mux available at this stage to test on a car).
    For info I've used 32 Gb USB key to install XENTRY/DAS instead of standard DVD. I found this very convenient because you can manipulate disk content as many times as required (for instance disable antivirus, IE8 ...) or replace files by other more appropriate ....
    But now, I'm facing internet explorer not connecting to sites (like google for instance). It starts searching but search never ends ! Since I suspect this to be in relation with Xentry/Das installation, may be do you have an idea ?
    In the meantime, pls have a good night.
    Bye,
    DK Veteran ontmiss's Avatar
    Jan 2011
    Hi DB_Member,
    Bye,
    go to C:\Programme\SDnetControl and rename NetworkFilter, restart comp
    Apr 2010
    Quote Originally Posted by ontmiss View Post
    Hi Ontmiss,
    I've done what you say and it works. But what about functionning of SDconnet C4 Mux that I intend to acquire ?
