Vu+ Drivers kernel 3.1.1 and above only.
Results 1 to 13 of 13
    Sep 2010
    Default Vu+ Drivers kernel 3.1.1 and above only.
    as the title says these new drivers by Vu are only to be used on images using the 3.1.1 Linux kernel and above.
    20111222(Needs Image update)
    - Switch to kernel 3.1.1
    - Improve recording(reduce load)
    - Improve vtuner performance
    - Support german remote keyboard(ultimo)
    ( these are already included in the ViX image )
    Duo
    http://www.megaupload.com/?d=NZBDVJBU
    Solo
    http://www.megaupload.com/?d=F42D6CXK
    Uno
    http://www.megaupload.com/?d=W85OD3LU
    Ultimo
    http://www.megaupload.com/?d=ILJ9G5ZA
    Sep 2010
    - Add security enhancement
    - Reduce FPGA update time(uno, ultimo)
    - Improve recording
    Sep 2010
    - fix 3d setup in MODE1
    - fix ui position setup problem
    Sep 2010
    - Add interface to check genuine box
    - Fix recording stop problem.
    Duo
    http://www.megaupload.com/?d=J9ZLMDNH
    Solo
    http://www.megaupload.com/?d=J1HC21HE
    Uno
     http://www.megaupload.com/?d=HKYAID6J
    Ultimo
    http://www.megaupload.com/?d=3PLMBVSX
    Sep 2010
    20120118 - Fix some DVB-CI modules recognition problem
    Feb 2012
    guys are the last drivers support the the usb wifi d-link dwa-140 B3?? is there any way in general to see what drivers are included in the set?
    Sep 2010
    Quote Originally Posted by streetball View Post
    These are hardware drivers for the receiver it self. all the necessary changes are within the changelog released with every driver release. Drivers for DVB-T USB sticks are usually included within the linux kernel or available for download vai the images own feeds.
    Sep 2010
    This is the entire changelog for the hardware drivers since the box was released.
    http://archive.vuplus.com/download/drivers/log.txt
    Sep 2010
    - Add support for dual S2 Tuner(uno, ultimo)
    - Fix HDMI recognition problem on some TVs(uno, ultimo)
    - Fix TS playback problem
    V.I.P. Member dell_xps's Avatar
    Backed up old drivers this time :-), loaded and rebooted no probs RD :-)
    Sep 2010
    - Improve TS playback
    - Improve Graphic 2D acceleration
    - Fix Russian VFD display(duo, uno)
    - Fix High/low symbolrate channel scan problem.(Uno, Ultimo : Need FPGA Update)
    -- UNO : Archive of Vu+
    -- ULTIMO : Archive of Vu+
    - Fix EOS detection problem in media playback
    - Enhance Security
    Download via
    Cheers RD :-)
    Did the FPGA Update also :-)
  13. #13
    Sep 2010
    - Fix tuner lock fail problem(ultimo)
    - Enhance security
    - Add bcm7356 support
