Results 1 to 5 of 5
Thread: samsung led tv
    Top Poster + flyin's Avatar
    Feb 2011
    Default samsung led tv
    what is the indicator in the bottom right of screen when pressing info button mean it has led tv and conventional tv meter type thing with a battery indicator any suggestions.
    Default samsung info button
    i think you will find that the meter is an estimate of how much power the tv is using depending on the backlight settings. if you lower the backlight the meter will drop down.
    Jan 2012
    its just the battery life
    Feb 2011
    What battery is that then enlighten me I'm concerned my new tv relies on a battery
    DK Veteran R_J's Avatar
    Jan 2009
    Canada
    Your LED TV includes a gauge that appears in the lower right corner of the screen whenever the "INFO" button is pressed. This gauge shows how much less energy your LED TV is using, compared to a conventional television set, for the current picture on the screen. During a dark scene this gauge will be very low, and during bright scenes the gauge will be higher. There is no way to disable this gauge from appearing when the "INFO" button is pressed
