Results 1 to 6 of 6
    Sep 2010
    Default ipod 4th gen facetime
    hi can anyone help my son has ipod everything works fine howerver his cousin got one for xmas now everone can facetime but on cousin one she cannot add a contact the only difference i can see is that on the top right hand side of the screen she does not have a cross to add people.she also cannot imessage .thanks
    DK Veteran fijiman's Avatar
    Oct 2010
    Wales
    iMessage requires ios5.x.x..... so make sure all iPods are all updated to the latest firmware..
    Sep 2010
    thanks for reply both ipods had been updated i have found if i reset ipod it would facetime and imessage but if i then connect to itunes it goes back to not letting me add or imessage??
    Jan 2012
    Quote Originally Posted by ack1234 View Post
    reset ipod
    go to itunes preferences
    under devices delete the backups of your devices (obviously if they're important don't do this)
    plug in ipod
    May 2012
    For some reason the USB 3.0 "bracket" ports stopped working. I also have two onboard/integrated USB 3.0 ports located in the I/O ports but they work just fine. I originally thought there was a problem with my external USB 3.0 HDD but I've tried several different USB 2.0 devices and memory sticks and cables and still nothing.
    Jul 2012
    Lyon
    this thread is for longtime. i don't know if you have solved this problem or not, as this situation, you could try to upgrade the itouch which can not running facetime, and make sure one of the device has the contact info of the other one, then with the wifi, facetime works, have fun
