Page 14 of 23 FirstFirst ... 4910111213141516171819 ... LastLast
Results 196 to 210 of 332
  1. #196
    Nov 2008
    Perfect thread for me to ask a general question
    I have noticed english subtitles has never worked on Asian channels on 28e, it appears on screen and vanishes very fast however it works fine on english channels just fine.
    Has anyone found a firmware that is working for Asian channels with english subtitles?
    The strange issue is french works fine....
  2. #197
    Jan 2013
    will this work on f5 mate?
  3. #198
    Nov 2010
    Quote Originally Posted by antwalk9 View Post
    Bit late but yes it will as Ive just put it on an F5 recently with no issues other than renaming favs.
  4. #199
    Nov 2010
    Quote Originally Posted by tazg101 View Post
    Hi any chance hour next update could have syfyHD , thanks
    Bit late but has now been added. List has been updated to todays date with some minor updates.
  5. #200
    Feb 2013
    can u still acess adult channels
  6. #201
    Quote Originally Posted by asifanas View Post
    Yes they are there but not in the favs,
    Sent from my Nexus 4 using Tapatalk 2
  7. #202
    Feb 2013
    Hi Im new to this where can i get a Cccam.cfg file thanks
  8. #203
    Feb 2013
    will this work on m5 mate?
  9. #204
    Feb 2013
    Default updated channel list
    hi can anyone direct me to an up to date channel list for the F3 thanks
  10. #205
    maca's Avatar
    Feb 2009
    liverpool
    Well you found dk im sure a bit of searching you'll find what you wish for
  11. #206
    Default adult channels
    how to add adult channels on skybox f3.
  12. #207
    Default Channel list
    as explained here i did put that file to get bouquet and channels but channels are back but not the bouquet where i can divide the channels like music entertainment sport etc what i am doing wrong plz help and want to add adult channels as well.
  13. #208
    Nov 2010
    Quote Originally Posted by cramman1986 View Post
    It is up to date.
  14. #209
    Nov 2010
    Quote Originally Posted by paul93 View Post
    You will have to do as below.
    Adding Bouquet to Favs
    To clear the existing name (fav 9, 10 or whatever) press the red delete button to remove the letters till the screen is clear.
    Then use the up/down/left/right arrow keys to select a letter. If you need a capital letter press the yellow button once to change from lower case to higher case and press yellow again to go back.
    When you have entered the name you want to keep press the blue button to save.
    Adding Channels to F3 F5 M5
    Menu > Edit Channel > ok > Favourites Edit > Red Button to go to All Satellite > Press
    Fav Button and choose fav bouquet you want to add to.
    So left pane will have All Satellite list and right pane will have Fav Bouquet list that
    you want to add to.
    In Left pane scroll to channels you want to add and Ok so it has tick, you can choose
    multiple channels.
    Once you have selected all channels you want to add to this Fav Bouquet > Right arrow to
    go to Middle Window > Press + button to add channels to Fav Bouquets > Right arrow to go
    into Fav bouquet and check that the channels have been added > exit and ok to save and
    return to tv screen.
  15. #210
    Feb 2013
    How many channels are there?
