Results 1 to 5 of 5
    Dec 2011
    Question How has burning with OPC affected yout burns?
    I am curious to hear from users of the LT Max firmware and Ihas burners as to how has using OPC (optimum power callibration) improved or worsened the quality of burns. I seem to have more problems with it on, than with it off, so I am considering not using it at all. I have seen where it is suggested to be used only for 4x burns, but I just want to hear from experienced users. I am using Verbatim mkm dye 8x Singapore.
    Thanks!
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Have slowed mine down. Clear opc every few burns an check with kprobe. No issues here
    DK Veteran martiboy's Avatar
    Nov 2008
    bonny scotland
    I have mines ticked for on. I use mkm 003 verbs. burn at 4x. never had 1 bad burn since using my ihas burner. for years ive always used verbs and can prob say that in over 1000 discs ive had maybe 2 bad discs. What i would also say is alot of people seem to be getting consfused with a bad burn. I flashed 2 xboxes on monday. tried mw3 in both boxes 1 came up with "disk authorization failure" while the other was fine. Gave the box a small pot tweek and it was fine now plays all games.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Have you checked any with kprobe? Mine are always good results. Will post some later on when I do some burns
    Dec 2011
    Thank you for the input. I think I am just going to stick to 2.4X and leave OPC off. Kprobe2 gives me better results without it after comparing burns. I just thought it was weird that it was recommended on at 4X and it produced bad results for me. I guess every PC is different though.
