how to transfers psp games from pc to psp
Results 1 to 9 of 9
    Apr 2011
    Default how to transfers psp games from pc to psp
    DK Veteran andy1weir's Avatar
    between glasgow and edinburgh
    well first off you have to have your psp running custom firmware, then its a case of creating a folder on your memory card/ internal storage named ISO (must be in capitals) then all you do is drop the downloaded iso/cso files into that folder
    Jan 2012
    Thanks will give it a try!
    Jan 2012
    You should first find a way to install the custom firmware, because this isn't done as easy as it sounds.
    After that, just create an ISO folder, inside the GAME folder (both after you installed the CFW), then you should be able to play the games after transferring them.
    Good luck!!
    You said it has to be in the GAME folder, not true, as mine just goes in the ISO folder on the root of memory card
    Sent from my Dell Streak using Xparent Blue Tapatalk
    Apr 2011
    do u know were i can get the custom firmware thanks.
    Nov 2011
    I remember having the old stream up at work. It's a nice stress reliever, granted you work in the IT dept and your internetz are not filtered.
    Apr 2011
    my systems a version 6.00 can i still hack it.
    Jun 2013
    You don't have to transfer, for there is version for PSP available already!
