can you give me more informations?
i'm interesting!
i'm interesting!
You can't do later RSA EDC17 via OBD yet as far as I know?
Byteshooter is a good tool for edc17.
Best regards
Original Kwp2000+ and other...
No stress for all !
I use magpro X17 and works great.
Also the T-boot works and cost less, but you have to open ECU.
x17 is an add-on to the normal, so you need the full pack which is not cheap?
ok, that probably works, but it is a professional solution and big package way too expensive for a tool used for 2-3 cars.
powergate tool is cheaper if you know which brands of cars you have.?!
if you want quiet advice do edc17 all time boot mode..
best regards
professional chiptuning and electronic car repair...four-DynoRace_ wheel_ dynamometer
when u do boot mode, do u have to connect to pads or pins on connector
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Ecu pins mate, and boot pad inside ecu
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
