Page 109 of 174 FirstFirst ... 95999104105106107108109110111112113114119159 ... LastLast
Results 1,621 to 1,635 of 2954
Thread: CARPROG FULL
Hybrid View
    AKAINTERN's Avatar
    Dec 2012
    here are my pictures when connected my clone and run soft 5.15
    Dec 2012
    Thx.....very usefull
    Multipla's Avatar
    Turin,Italia
    I read this dash, A3 year 2006, but dont write the dash. How did you do? I've only read 5 Golf Protocol but I couldn't write anything. I have 4.01 I anger doesn't solve the problem. That solution might adopt. Thank you all in advance and also those people who responded first. Shmortz says his CarProg works fine but then spiegaa how did. Thank you
    AKAINTERN's Avatar
    Dec 2012
    Today checked dash for AUDI A6 2006 with software 5.15, failed writes (unknown A6/Q7) !
    someone did such a machine ?
    Lithuania
    Yes with orginal, and not remember sw version. Maybe 5.21... Costume from codecard
    Dec 2012
    GARAGE
    Hi friends!!!! If anyone of you tested version 4.1 with adapter a9, my carprog test ok adapter a1 ok, but do not respond d1
    and were a little afraid to use it.
    It would be great if someone has tested your. pleeessss
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by marmaro View Post
    a9 doesn't work with clones.
    Dec 2012
    GARAGE
    Quote Originally Posted by bearheroes View Post
    I made a9 by carcode and test my clone: results carprog list of pins ok ok ok ok ok ok test on a1 in car -ok , d1-not respond ,if someone has adapter a9 please try.
    If anyone has, please upload the pinout of the a6 carprog clip - mine does not read on plate, only desoldering chips and turned upside down.
    spychu14's Avatar
    May 2011
    POLAND
    Two simple questions :
    1.What chip is on D1 Adapter ?
    74HC125M ?
    2. Anyone see difference after flashing MCU with DK dump ?
    I don't have counter yet but i will flash MCU if this help.
    VAG
    Dec 2012
    GARAGE
    Question
    Quote Originally Posted by spychu14 View Post
    74HC125M ?
    chip in my D1 adapter is no name and in carprog too.
    Can I easily check them somehow?
    filutek's Avatar
    Silesia
    74HC125M ?
    Yes chip 74HC125.After uploading there is no difference counter returns.
    mijatx's Avatar
    My D1 FOR CP CLONE 4.O1 Also do not pass A9 test but works OK so far!
  13. #13
    Aug 2012
    Polska
    hy
    someone tried bmw e60 2005?
  14. #14
    Quote Originally Posted by Pakli30 View Post
    hy
    I wouldn't risk it with s**ty car prog clone unless you wanna buy a new cas unit
  15. #15
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Can I make km correction on Passat 2006 with Clone carprog. What dash has this passat?
