Page 110 of 197 FirstFirst ... 1060100105106107108109110111112113114115120160 ... LastLast
Results 1,636 to 1,650 of 2954
Thread: CARPROG FULL
  1. #1636
    ovi_dk's Avatar
    On board
    Quote Originally Posted by TERNOCOD View Post
    Hi.
    CarProg all versions incorrectly works for Blaupunkt SPI EEPROM 25160, 95320, 95640. To be more accurate in all numbers of the code changes the numbers 8 and 9.
    I have version 4.85, 4.86 does not work for code definitions in car Blaupunkt with SPI EEPROM.
    Does anyone have a higher version 4.50 and lower 4.85. These were?
    B.R.
    here u find all versions
    http://www.digital-kaos.co.uk/forums...7/index95.html
    regards
    If u have the answer say Thank You!!
  2. #1637
    Meat-Head's Avatar
    Cool, Reno Clitto 2001 - Spoke ro BCM - gave pin code out, but another tool said wrong code.
    For a laugh tried to reprogramme the key, said entering pin, ok.
    Saved the dump, Reno Pin Reader said bad dump.
    Was able to edit the chassis number to something rude.
    Will try and get an orginal and CP dump next week.
  3. #1638
    Oct 2011
    Usa
    I bought a new AT91SAM7S256, and i could program correctly with wiggler and h-jtag, also verifyed ok
    After connecting to usb port not detected!!!
    Now i can not erase it, or maybe it is dead
    So im keeping my original, till the counter goes zero!
    Can someone program a new MCU and send to me? (=$$$$)
  4. #1639
    badenaleks's Avatar
    Feb 2012
    Windy City
    wondering if I put the video on restoration karprog. password in PM!http://www.digital-kaos.co.uk/forums...14/index3.html
    Do not forget to click thanks!
  5. #1640
    Lexas's Avatar
    had my cp in car boot for a week, today try to use, looks completely dead... when connecting usb, green light comes on, but no communication at all. take out pcb, found slightly wet inside (rainy days, very wet weather). Make it worm with hot air an cp comes to life. So lads, keep that joke in dry place
    Don't Forget Button
  6. The Following User Says Thank You to Lexas For This Useful Post:
    Automat (4th December, 2014)
  7. #1641
    Sep 2012
    Whether the program is working on several programmer or just carprog programmer?
  8. #1642
    Carprog is realy annoying on this one. The dump in car prog is halved. A 93c66 dump is duplicated when read with an eeprom reader. Only half is displayed in carprog so when you import dump its too long. Then when you proceed it falls over ( carprog that is. )
    Also when you power up the uch the dump is moded in the micro controller so then when read again its not quite the same.
    There are 3 variations on the algo codes and carprog only does 2 of them well.
    I always work in 8 bit mode on this one.
  9. #1643
    Meat-Head's Avatar
    Quote Originally Posted by albertros View Post
    Carprog is realy annoying on this one. The dump in car prog is halved. A 93c66 dump is duplicated when read with an eeprom reader. .
    So sake of argument the costomer wanted the code say.
    The dump carprog made, cut and paste it's self into say usb-upa, xprog etc, save then run through zedbull or reno pin reader, then, bingo number is.........
    So 'what' was the code on the screen and 'what' is the correct code (will TRY and upload dump next week)
  10. #1644
    Austria
    Can someone check on their clone.
    Carprog+usb+A1 (power +12) = check voltage canlow/hi, pin 6 and pin 14 ? Not connected to car.. on table.
  11. #1645
    Aug 2011
    uk
    Default re carprog
    Tried to connect to psg16 pump signum (same as veccy c), via obd, it does not connect to ecu, it says " COULD NOT SEND CAN Kwp PACKET" , ANYONE have any ideas why?? I also checked A1 adapter and the black wire in the plug was not connected(which goes to pin 7 k line), Anyone think its just A1 adapter thats shot?? Carprog reads 24c16 ok and serial Number is in bottom left of screen.
    Think this is possible pin 6 and 14 can lines but dont know how to test this on the A1 adapter, Any help appreciated
  12. #1646
    DK Veteran Carsoft2003's Avatar
    Mar 2011
    Algeria
    Default The last update Carprog
    Hi for all member Carprog 4.95v
    work with clone carprog
  13. #1647
    prusony's Avatar
    Belarus
    Quote Originally Posted by Carsoft2003 View Post
    How about counter?
    Turn ON or not?
  14. #1648
    Oct 2010
    From Today -Audi RB8 dash works OK
  15. #1649
    Jun 2011
    Northamptonshire, UK
    Did a 2004 Vauxhall combo 1.7 td yesturday pin read from ecu.. all good..
    Music73
  16. #1650
    ahadi's Avatar
    theres counter always .never lock just available as new product .
