Page 139 of 197 FirstFirst ... 3989129134135136137138139140141142143144149189 ... LastLast
Results 2,071 to 2,085 of 2954
Thread: CARPROG FULL
  1. #2071
    Serbia
    Quote Originally Posted by Pakli30 View Post
    this is dash not so
    Maybe is better to put pictures of your dash
  2. #2072
    Aug 2012
    Polska
    sorry, this is dash, ford mondeo 2004
  3. #2073
    Aug 2012
    Polska
    and this is dash, not read my carprog clone.
  4. #2074
    Aug 2012
    Polska
    a10 be bad cable?
  5. #2075
    Prussia
    a10 be bad cable?
    OH a Ford Megane................unusual
  6. #2076
    Aug 2012
    Polska
    resolved, the gnd was not in the soldered a10
  7. #2077
    genius76's Avatar
    Dec 2012
    Lowestoft
    Put picture what was wrong with ^body^
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
  8. #2078
    i take my clone with 4.01 version.i test in laguna 2 dash with 908 mcu and work ok.adapter and 3cables and ok.laguna 2 programmed key card from obd and ok.i afraid to try for key in clio 2 id46 work?i read out from car the opel astra ecu hsfi2 and ok.i can read and in car from obd and how?i try it but not have can.or the cable have problem?need power external in car to read?or some cable must fix?but in laguna with obd some cable work ok for key.thanks
  9. #2079
    hacko12's Avatar
    Today i try change km on Peugeot206 2000y. read was good but not write.. my serial: ...1773I
  10. #2080
    Dec 2012
    maroc
    if p widi Liberare RCD 310
    with meclone
  11. #2081
    Aug 2012
    Polska
    35080 someone writing? writing goes through, but error checking.
  12. The Following User Says Thank You to Pakli30 For This Useful Post:
    alle bmw (28th October, 2014)
  13. #2082
    biktel's Avatar
    Jun 2009
    Romania
    For me works 35080 in astra h dasboard
  14. #2083
    for 9s12 1l85d can read with carprog clone?i try but not conect.the a10 and obd cable it is ok.nothink mising.it is good clone
  15. #2084
    Dec 2012
    maroc
    helo
    MASE am ateb clir sopri RCD 310
    diolch @ AAAAAA (chl?n)
  16. #2085
    marcolr's Avatar
    35080 is a incremental registry eeprom. If you haven?t a eraser for this eeprom you need change by a new one.
    Is for this that you obtain error checking, the problem is the first 32 bytes that you can?t put a lower value.
