hi
any one has good help files of carprog clone use....please need to know how these adapters works...means how to use A1 D1 and other wire adapters to use for airbag of ford ...and GM..and dashboard automatic calculations..
Today I test TOYOTA Key Maker ! And it's working OK
VW 1J0 909 603 A By K-line Working OK
CP China is good work
got the original to read / write the megane IR key Type2 on the right picture.
Generated a "new" key from the label in the broken key, key dump and code to program key worked fine.
Not tried type 1 yet.
Sure someone post not work with clone?
ON TOPIC:-
Can these vergin-ise IAW59F.com ecu's off fiats?
Spooky that meat.... I have just got one of these to virginise too... As far as I am aware there is no main section for doing them.. but probably possible through the eprom section of it...
Sent from my HTC Sensation XE with Beats Audio using Tapatalk 2
Yeah no end of people call me a freak as well as spooky. There is a thread about them iaw59f's
ON TOPIC:-
If you manage to verginise one, could you let us know how you get on using carprog.
Just for reference if you manage to get somewhere with it, do a search for member paul12345 he menetioned about boot mode and ignition afterwards - don't want you giving up with it yet.
You need every tool in the book, to do this auto locksmith job.
ON TOPIC:-
Justy22 - has yours arrived yet?
What is the quality of the cables like?
Soft and flexale, or delicate and brittle like a Poundland USB cable?
NOT SURE IF ON TOPIC OR OFF TOPIC:-
Justy22 when your carprog is in use, if you get a Poundland USB 2AA Ni-Mh charger, the lead has all FOUR USB connections wired.
See if like when i used it to charge my cell phone it lasted three times before it broke.
(The other one is fitted to somebody's car i don't like)
My Carprog arrived Today in perfect condiiton via DHL, all leads look good quality, very happy with it
