Check that resistor inside A10 cable.
alladdin205 (13th December, 2013)
let me tell somthing
if you wond to help ok
if you dont whont to help ok again out you can not say to another here what to do all why tray to make our job or our hoby ok
thank you morfej for the sximatick of the cable
carprog have alla the sximatic of cable in the site
me dealear is ok and send me mcu to fix me problem put the problem is that i can not sold the mcu
and for that i ask if you have another way to fix me problem
thank you all
ecu opel k-line
delco hfsi2.5 /ok
simtec70/ok
simtec71/ok
can opel
edc16c9 /ok
edc16c39/ok/fail/ok/fail
simtec 71,5/ok
Press " Thanks " button, If my post was helpful
Automat (29th December, 2014)
If you choose a SMD resistor:
ON TOPIC:-
No idea of how much currant passes through this, but 1/4 Watt might be better
OFF TOPIC - BUT RELEVENT:-
Alfa Romeo GTV - horn fails, on the circuit board is a 0 Ohm resistor - just used as a bridge on the circuit board, these burn out.
Just working a horn relay, approx 150 MA.
HTH
Meat.
Hello.
In Renault Trafic II. I try read the pin, strange characters appear in the VIN. The attempt to Clio II and the reading is correct VIN and PIN.
My Carprog clone read and write in the section of EEPROM, but no section in the Dashboard.
Best Regard
Do you think know it all?.... You will never learn!!!! Read, listen and think what speak or write.
Here if someone have problem CarProg can use these loop back adapter and test HW.
It is A9 adapter. HW TEST is in UPDATE section of Software CarProg.
[I]Automotive Electronics Solutions
Mercedes-Benz Reverse Development Engineer ...
Mercedes CFF 2010-2017 CFF all models all modules
Vediamo help flashing over teamviewer ...
JLR SDD online + offline ...last official ...
you soon get confused!
in carprog you can use it as an eeprom programmer, if there is a glitch on the renault programme for example you could read the eeprom directly ..95040 for example.
I dont need to go in that direction as I have spent money to be able to do jobs like this quickly, without drama, using a more expensive tool.
please dont ignore my request for to you to apologise to Arthurs daughter for your insulting remarks, [dont think ignoring me will make it go away
