Yeah the slight inaccuracy of the algorithms cause's them to flutter around
Sent from my HTC Sensation XE with Beats Audio using Tapatalk 2
yes. for you , guys from uk needs to be made always special tools.
Personally I would calc what I want in miles to kms and then enter that as it seems to be giving you the value that would be kms converted to miles...
on topic
Today i tried to read ews 3 with od46j inside no succes.
I use k-line bench flashing adapter lead i had with my Byteshooter MINI kit. Then use A1 EOBD adapter to plug into it. The bench flashing lead has its own 12v + earth lead, so this powers up the ecu or cluster or airbag unit, then use the 12v supply lead from Carprog to power the interface from the power supply.
[QUOTE=
how do uou connect carprog to ews module?[/QUOTE]
there is special cable on kit
Anybody tried rns510??????
Hi !
I try to read an ST92F120. In Carprog menu I have only ST92F150/250.
However I connect wires like that --> ST92F120, ST92F150, ST92F250 internal EEPROM programmer
and I receive only 043D 0000 8B55 33EC. If only one wire I disconnect then Boot error receive.
Who have that problem and how solve it ?
Carradio2001.
Is there any way to change odometer with carprog clone on volvo cars?
I have version 4.01
may be disabled in soft , there is Carprog cracked soft V3.42 .
