we are talking about 912 motorola from 2005 on.
immed. before that it was eeprom from 2003 ish black back,
before that white back it was old processor.
dont confuse the fact that cars will communicate via obd for scanner, that doesnt mean you can do miles via obd
off topic
ps. dont you think an apology to Arthur is in order?
Hi, I just bought the carprog clone 4.01, I made some tests:
93xx eeprom read/write > OK
24xx eeprom read/write > FAIL
95xx/25xx eeprom read/write > OK
Airbag Module Ford Focus 2004 Bosch 0285001555 > OK
Car radio Symphony I & II decode by direct connection > OK
Car radio Concert I & II decode by direct connection > OK
Dashboard 2004 Toyota Corolla 93c46 > OK
Dashboard 2003 Toyota Echo 93c46 > OK
Dashboard 2007 VW Jetta OBDII > FAIL
Dashboard 2005 VW Jetta OBDII > FAIL
Car radio Philips (with 24xx eeproms) > FAIL
MCU ST92F150 Read > FAIL
I made the Hardware test with adapter A9 and Test is OK, I think the problem is in software not in hardware.
Automat (29th December, 2014)
Code Calc for FORD M and Chrysler 6 Buttons works OK ! .![]()
You mean the vw update, come on its there for decenia.
Carprog is very late with his update, some kind of logic because the tool is a multipurpose tool.
If you want a good Milleage tool, buy the real machines if you want good tools that for not tomuch money buy smok.
I bought some smok tools and for now they did what they suppose to do.
regards Adam.
Solution for CarProg clone COUNTER finded and OK.
Do not PM me for solution I DONT SALE IT !
And I will not share it !
Only I give info.
All best to all ;-)
[I]Automotive Electronics Solutions
Mercedes-Benz Reverse Development Engineer ...
Mercedes CFF 2010-2017 CFF all models all modules
Vediamo help flashing over teamviewer ...
JLR SDD online + offline ...last official ...
