Does the CP clone 4.1 work with programming renault keys via OBD?
Anyone tested with success? or does it need higher version no. ?
Hi! I checked with vivaro `04 - pin reads correctly but the keys are not programmed , opcom work success!!
obd.tech (7th April, 2013)
clio read pin and programming key obd ok
laguna2 read pin ok, key must programming with can clip
laguna 2 read pin and program card ok no need any clip. megane 2 scenic 2 via can not work.
Is carprog clone any good for airbag module repairs and extracting pin codes for key programming even on new cars such as VAG, etc
Don't forget to hit thanks button
i have carprog 4.01 no read dashboard w 2008 micronas
help me thanks
For VW 2008 micronas you need buy new original![]()
any clip is renault can clipmy carprog clone cant programming card, only read pin
you can not program card with clip if card is not prepared by vin from factory only with very old version of can clip (till ~v70). If you change pcf in your card and prepare it so you can program it with carprog or any other device but not with can clip. I know about this older renault not so bad.
Clio 2002/2003 year, carprog finished all
Yes of course, I prepared pcf for laguna keycard with zed bull, and login with can clip, and pin is read with carprog
obd.tech (9th April, 2013)
Hi !
is there any deference bet win MM74hc125m and CD74hc125m or MM74hc126m ?!
thank"s in advance
My work is my life ART TECH GARAGE
Its all the same
Look
http://pdf1.alldatasheet.com/datashe...S/74HC125.html
http://www.ti.com/lit/ds/symlink/cd74hc125.pdf
Only its diferent factory
mexanico1971 (8th April, 2013)
