Hello friends
to see if they can help...
Is to read and write micros family freescale hc08 6811 68hc12 hs912 motorolla....
To see I mean I've had Chinese upa programmer without success, I've had developer xprog-m without success
've had original upa House without success and I've had to return because I do not read.
Pinear a motorolla with 6-7 pin micro already is difficult but if above the micro has 100-112 pins even much more difficult if not impossible.
and of course all this pineando according to the datasheet of the micro and each programmer according to the indications.
Then wonder:
What are the pins needed to be able to do a reading and writing of the micro-motorolla without having to pinear 7-8 pin.
Because the voltage Vdd pin are needed and then the pins of data transmission trx and reception of data
rx, but which are necessary for pinear well the micro and let me correct reading....
Because another option would be for example in airbag switchboards, read and write the microphone through the rules on the control box as it does the machine super vag k can
but can you tell how to reduce to the minimum the number of connectors of the micro way motorolla.
If food through the connection of the switchboard of airbag connector (connecting only positives and negatives) and pinear in the micro only motorolla necessary pin for data transmission and that allows reading and writing of the micro...
Can help me, as do a reading and writing easier through rules just connect 2-3 pin.
Can help. because I have a big problem with the micros motorolla frrescale
sounds or that programmers for microcontrollers motorola freescale non-upa-usb, and that works.
As to launch the programmer xprog-m and make it work because with the motorolla monkeys when was pinea appears "device is silence"
greetings I hope your answer
thank you and happy year 2012
